Advice please - tingly fingers
whybrowr
kent
Sorry was not sure were to put this. i have been cycling for a few weeks now and doing well my tine for my trip is coming down and i dont feel dead when i arive which is great. my only real problem is i get tingly fingures and my hands feel weired not tingly and not numb but somewhere in the middle i guess. can any one tell me what is causing this and what i can do about it please
many thanks Rich
Likely pressure on the ulnar nerve, also known as cyclist palsy, Google can provide insight. Good bike set up, good posture, not gripping too tight, ergo grips or good padded bar tape depending on bike type, changing hand position, good padded mitts can help
There are plenty of threads on this is you use the search function, e.g. If you put numb in the search box
https://www.cyclechat.net/threads/wifes-right-hand-goes-numb-ish.181901/post-3782069
https://www.cyclechat.net/threads/pins-and-needles-numbness-in-hands.155646/
https://www.cyclechat.net/threads/tennis-elbow-and-numbness.178388/#post-3655992
https://www.cyclechat.net/threads/painful-wrists.171546/#post-3451488
https://www.cyclechat.net/threads/my-hands.166243/#post-3306168
There are plenty more :smile:
shouldbeinbed
Rollin' along
Manchester way
^^^ A tad expensive compared to say, better bar tape/ergon grips dependent on the bike type.
@whybrowr no doubt it is mentioned in the numerous threads linked but make sure all your contact points with the bike are right : saddle, pedals and bars are all interdependent and e.g. adjusting saddle angle or fore/aft position could assist your hands. You could also work on your body core strength to support your weight in your torso more than leaning on the bars.
Gasman
Old enough to know better, too old to care!
Actually it's more likely to be pressure on the median nerve which is fairly superficial at the heel of the hand and gets leaned on when you grip handlebars. Padding, position and lift your hands off the bars occasionally (one at a time) and wiggle it about to relieve the pressure.
