Discovered something surprising.
The first years I used my current fixie, I had the regime of let things wear, flip now and then, then replace all 3 drivetrain parts.
Begin 2019, I mounted the last new chainring.
Begin 2020, I had to replace the chain (eccenter at its end) and decided to let the worn chainring in place, and added a spare to my equipment in case teeth broke off along the road.
Oktober 2021, I replaced the chain again with a new, and due to the delivery problems caused by the lockdowns, I decided to still leave the worn chainring there.
It's now end may 2022, the chain wore faster than usual (tried a non oil regime, see other topic), and the eccenter sits close to its end.
But the chainrings state is basically unaltered since begin 2020.
Apparently, a new chain doesnt wear an old chainring.
Meaning that when you replace your chain before chainring "continues" wearing, a chainring almost lives forever.
Since some days, I heard a rattle at the chainring. Has been long ago I heard that. Out from experience, I know that this signals that it's time to flip and/or rotate the chainring on its mount, which I did today.
I inspected the chainring while doing it. Remarkably, the teeth were barely worn more than begin 2020.
Meaning that the chainring nearly ceased to wear further.
This indicates that it is the longer becoming chain that inflicts nearly all the wear of the chanring.
Last year I played with the idea of a wider (1/4" motorcycle sprocket, but didn't find a compatible one).
This probably would have proved having been a useless idea, because it wouldn't affect chain wear, and thus its elongation, in any significant way.
And another final element I started to wonder about.
Chainring teeth wear towards a sharkfin shape.
The fin of the teeth is directed backwards of the bike.
Never stood still about that so far.
But now I did..
What happens at the front cog - the chainring, the cranks, the pedals?
Your feet press the pedals. The crank makes the spider turn forwards, the chainring mounted on it rotates forward.
The front edge of the teeth of the chainring thus press against the "back" position N(they can roll...) of the rollers of the chain.
Agree?
So, shouldn't the front edge, being the against a chain link roller pushing edge, of the teeth wear?
Wear = removed material.
So, the "after wear remaining teeth part", the "last material to wear away", should be at the back of the teeth, not the front, and the teeth thus should have a pointed forward instead of backward sharkfin shape, no?
Apparently, it is the opposite, the sharkfin shape points backwards, alike the rollers of the chain push the chainring teeth at their trailing edge, Alike the bike / rear wheel/cog is pushing forward the bike, instead of the cranks, clearly not the case.
Or, I'm wrong somewhere in this thinking.
But now I did..
Agree?
