clicking driving me insane!!!!!
rugbyluke
A distinctive irregular clicking noise from crank area when pressure is applied to the pedals ( not when cruising .............DRIVING ME INSANE!!!!
Please someone help. I have done the following
Greased the pedals
Greased the chain ring bolts
Tightened the seat post(just in case)
Bottom bracket does not seem loose
screenman
Saddle rails?
PeteXXX
Hamtun
I had similar, but more of a 'gronking' noise. I'd intended to remove and check the BB but after loosening the crank arms and finding I didn't have the tool to remove them <DOH> I squirted some lithium grease around the place and retightened the crank arm bolts.
Not sure what I'd achieved, but the 'gronk' disappeared..
screenman
Pedal standing up to check for that.
I know that but you will be surprised how many do not.
Saddle rails.
Seat post.
Where the cables stop on the down tube.
Speedo magnet touching pick up.
4 very popular places for noises to be coming from.
rugbyluke
rugbyluke
It sounds like when your teach a torque setting on a torque wench
andsaw
I had a clicking on my new cannondale and i tracked it down to my handlebars, it had half thickness carbon headset spacers that had 3 lugs that took the other half thickness, so anytime i put a bit of pressure on the handlebars it started clicking, i think the spacers were flexing so changed to alloy ones and the clicking stopped
spiderman2
Harrow
Had the same clicking from my bb on my specialized Roubaix ,took it back to the shop and they checked and re torqued the bearing .So far hasn't come back
slowmotion
Quite dreadful
lost somewhere
The bolt that holds the crank arm onto the shaft of the BB might be loose. I had the same kind of noise on a recent ride. The experts diagnosed it quickly and did up the bolt. Silence!
betty swollocks
large member
Check chainring bolts - tighten.
Take pedals off, re-grease treads, refit, ensuring they're tight
Take out seat post, give it and inside of seat tube a clean, re-grease and re-fit.
Are the handlebar bolts on the stem tight?
