Ricd11
- Wolverhampton/ Cardiff
I apologise if this has been asked many times but i've searched the forum and can't find exactly what i am after.
I have a brand new Ridgeback Voyage, but it will not change down to the lowest sproket on the triple chainset. I had a butchers on bicycletutor, and had a fiddle with the adjustment screws on the front derailleur. I was able to get it to shift down to the smallest sproket, however when I went on the middle sproket to test the range of gears the chain started to rub against the derailleur on the top 2/3 gears. I then tried adjusting the upper limit, but I can get no compromise between making the lowest sproket and not rubbing running through all the gears. So i'm stuck at the moment with either no lowest triple or no chain destruction.
The video on bicycle tutor did mention trim, but i don't really know what this is. Also after looking at the bike, the front derailleur seems to be 2-3mm off the largest sproket, where the video states 2mm is advised but the lower the better.
The derailleur is a shimano sora triple apparantly.
Any help would be greatfully received,
Thankyou,
Rich
Thankyou,
Rich
