1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
iq cyo burn out
Discussion in 'Bicycle Maintenance, Mechanics and Repairs' started by chirk2000ad, 28 Dec 2011.
  1. chirk2000ad
    chirk2000ad New Member
    lancaster
    Has anyone experienced this?
    I was cycling along in dark, dry conditions. I stopped for a break and then when i started off again the b & m cyo wouldn`t light up. I had to ride home on the emergency lights. Luckily i wasnt too far from home.
    When I checked the hub dynamo (shimano) output the voltage was good so I stripped down the cyo. On the PCB inside several of the tiny components in the bottom corner had fried and burned out, but I couldn't see why as there was no water or debris ingress.
    I have had the unit for about 2 years but am pretty sure its outside of warranty. The led still works as the standlight is still functioning.
    Needless to say I am a bit taken aback that it went like this as I thought that these lights were designed to give many years service. I wonder if the b&m would replace or if they would be interested to see the failure as I bought the light from a supplier in Germany?
    Also gives me doubts over wether to go for another cyo? Anyone else using a dynomo front light and managed to get more than three years out of it?
  2. Milo
    Milo Veteran
    Melksham, Wilts
    You can only try the worst that can happen will be they say no.
  3. Little yellow Brompton
    Little yellow Brompton A dark destroyer of biscuits!
    Bridgend
    I got water inside both of mine and emaile B&M ot ask how I could take them apart to dry them, they took a while to answer but came back with a very polite apolgetic reply asking me to send it to them for replacement.
