ChrisEyles
- Devon
I've just finished doing up an old 90s mountain bike for off-road fun and games, and one of the many things which needed a fettle was the upper jockey wheel. It was very stiff, to the point where turning the cranks backwards caused the rear derailleur to pivot around rather than the chain moving through the jockey wheels as it should.
I tried to solve this by loosening the bolt fixing the jockey wheel to the derailleur cage, and initially this seemed to work fine.
However, on tonight's test ride, the bloomin' thing fell off! I managed to find all the parts except the bolt (wasn't easy!), which I've replaced with a suitable new one, filed down to the correct length so as not to snarl in the spokes (I hope it's suitable anyway... it's threaded all the way along, and I suspect the proper bolts are smooth in the middle and only threaded at the end?).
Now I'm left with the same problem - if I tighten up the bolt, the wheel stiffens up, and if I loosen it so that the wheel turns freely I'm worried about a repeat performance, only this time a lot further from home.
So, I've got a few questions
1) how tight should this bolt be done up?
2) is the solution to this simply a bit of threadlock to hold the bolt in place in it's slightly loose position?
3) is it possible my jockey wheel is missing a spacer/washer that would take the squeeze from the derailleur cage while still allowing the wheel to rotate freely around the sleeve bearing (that's how I'd design it if I was making one, anyway). If so, can this be bodged, do you think?
Thanks for reading!
Thanks for reading!
