Custom24
- Oxfordshire
Hi
I've Google'd this, but that's just confused me.
Specialized Hardrock 24 speed Mountain Bike (Hard tail). This is all my own doing (no LBS involved)
My old chain (the second chain on the bike from new) was worn >1% according to the chain tool, so I replaced it. I bought a KMC x8 .93 SP chain this time, which I think is very similar to what came with the bike originally. I measured it and counted the links versus the first chain that came with the bike.
Now (instantly after replacement), the chain is jumping when in the smallest sprocket on the cassette, when under load. I can see it happening on the bike stand if I use the brake as a load. It's not trying to move sideways or change gear - it looks like a link is "hopping" upwards off the cassette momentarily.
I thought the problem was indexing at first, so I replaced the gear cable which needed doing anyway and adjusted the indexing stops and tension so that everything is perfect on the stand
When cycling, the smallest sprocket on the cassette is unusable - it is hopping continuously (which makes me think not a stiff link, because it's constantly doing it). It is also happening to a much lesser extent in the next sprocket up, and even a little on the one up from that, although I can't see those jumping on the bike stand.
The peculiar thing is that the first chain lasted about a year before the chain tool said it needed replacing, and the second one only lasted about 3 months. I wonder if the second chain has chewed something? The second chain was also a KMC 8 speed, but I can't remember which one (except it was cheaper).
What to try next? If the answer is to replace the cassette and front chain rings, then I'm tempted to put back on the previous chain and just cycle on it and replace the whole lot at once when something fails terminally. It wasn't causing me any problems at all apart from the chain tool telling me it was worn.
Thanks
Mark
Thanks
Mark
