biggs682
Touch it up and ride it
- Northamptonshire
Been given these by an elderly neighbour , no idea where he got them from as he or his family do not cycle , so i have no knowledge or experiance of these bits so offering them cheap , feel free to make offers they need to go
First up is a Tensor Panther 24" or 61cm frame measured from centre of bottom bracket hole to centre of seat pinch bolt , labelled as made from lightweight Ferrolite hi tec 636 tubing ie nearly gas pipe .
its white and should clean up ok got some patina ie marks but cant see any dents or cracks , takes early type nutted calipers has 132mm rear drop outs !!
ideal cheap fixie or single speed build .
Asking £10 collected from NN8 post code or £25 sent through senditnow.com to any standard uk post code
Next up is 2 prs of SRAM Attack twist grip gear changers two are 9 speed rears whilst the other pr are 3 speed front all seem to twist ok in both directions for 22mm bars , the barrel adjusters all operate and the cable caps are all present .
Asking £5 for all of them collected from NN8 or £10 sent to a std uk postcode via my Hermes
