Pinnacle Arkose - brakes opinions please
I have mechanical TRP spyres with crosslever brakes on the Boardman. They work fine and more reliably than the BB5s they replaced which were ok when adjusted but just needed adjusting way to often for me
Tangoup51
... you chose spyres over bb7s for the boardman? egh.
Also yes, for the love of god, avoid the avid bb5. While mine work perfectly right now, I'd like to say that there is a special place in hell
for whoever came up with those 5s.
Why not Spyres, everyone I spoke to recommended them, needing minimal adjustment, which is easy (I'm not mechanically mined in the least) ...and they were cheaper?
Tangoup51
Why not Spyres, everyone I spoke to recommended them...not least cheaper?
I think bb7s are cheaper.
to me, spyres are a great standard to set disc brakes too, but bb7s are just that slightly more exceeding. They definitely learnt something from their previous model though :smile:
Don't know, the Spyres cost me £80. They work well, the LBS who fitted recommended them before I bought
I like Skol
A Minging Manc...
Disc brakes can be shockingly poor, but here is a little anecdote about an experience I had.
One of the kids bikes was stolen a year or two back. When it went it had excellent Shimano Deore M615 hydraulic brakes, they really did perform as well as my XT brakes.
When we recovered the bike the little scrotes had stripped the brakes and installed (badly) some Tektro cable operated shoot (Novela I think). They had also swapped the good wheels for junk so we now had generic unbranded rotors in place of some end-of-line discounted XT centrelock ones I had managed to pick up.
It couldn't have been a much worse situation but it was what it was so I set about 'optimising' the set-up. Cable routing and condition was sorted out, pads sanded up nicely and caliper adjusted to perfection. Still not great but better. I left them alone for a few weeks thinking they would bed in, but they actually got worse, to the point of being dangerously ineffective!
Time to get serious! Pads out and they looked dry but a little glazed so these got cleaned with a solvent and then rubbed up again and looked like new. Rotors were removed from the wheels and mechanically sanded until all traces of polishing had gone and both sides had a uniform satin/roughened finish. All now went back together and adjustment once again checked/tweaked to perfection. I then forcibly bedded them in myself and they got better, almost acceptable and now certainly not dangerous, but probably about as good as could be expected for a cheap set of cable operated disc brakes. (I have had no other experience of cable discs but have had the misfortune of Tektro hydraulic brakes which soon went in the bin!)
Over the following weeks, performance fell off slowly until it got to the point where I wasn't happy for my son to use the bike. I was ordering some bits for other bikes so decided to stump up and buy some new pads (Under £20 for 4 pairs semi-metallic, enough to do the bike twice).
I don't remember doing anything other than popping these in and adjusting clearances but on the first bedding in run the bite went from hmpff. to Whoa! On the second run the brakes were right up at the WOW! level. I would never have believed cable disc brakes could be so powerful, especially cheap ones. I guess the fact that I had done all the groundwork to make sure everything else was optimal helped but these brakes remained really good until we passed the bike on several months later. I would previously have rejected a prospective bike if it had come with cable operated disc brakes but now realise this would be a mistake.
@Crackle I guess this is your problem, the bike your wife experienced probably has contaminated brake pads or they need setting up properly. I suggest you tell the shop to sort it out as they will lose the sale unless they can get the brakes working as they should.
C
Crackle
I'm leaning towards the 1 because I think I'd like the option of fitting cross levers, still mulling though and I might ring the shop later and ask some hard questions.
Darren Gregory
Rides a Pinnacle Arkose 3 and a Trek Emonda SL6
Arkose 3 2015 owner here. Mine came with BB7 cable brakes. Worked fine but would need adjusting fairly frequently and I used to find that if I took a wheel off when putting the damn thing back on I would often have to adjust the brake again. Moved to hydraulic and whilst no perceptible difference in power so far no real adjustments needed.
Good luck with whatever you choose to buy, I'm a big fan of my Arkose.
C
Crackle
Well the Arkose 2 won the day.
C
Crackle
It's a really nice bike. Mrs C did her first ride on it this morning. No neck pain, only a little bit of hand tingling and she said it felt good, smooth and fast. So so far I think I've judged this right in trying to solve some of the problems she was having on her Cube. Need to swop the seat over from that and re-adjust the gears which were jittering under pressure. I did try to do it on the ride with the in-line adjuster but it was a bit cold to stop for long. She was very happy with the brakes and the bike overall.
I think the Arkose range is really well specced and designed. I'll probably need to change the gearing for her but I was expecting that but other than that, it's all good. Really lovely bike.
Darren Gregory
I really detested the supplied bar tape and changed that very soon after buying, your mileage might vary but changing might help the hand tingling?
C
Crackle
Tis a lovely bike, you spoil that woman.
Tiagra groupset should be excellent if my previous 9spd Tiagra experience is anything to go by.
Not me Skolly, she's perfectly capable of spoiling herself, though she took a bit of persuasion to spend that much on a bike when she already had one. N+1 has finally landed though.
