Removing Chainring Gaurd
braaivleis2003
Derbyshire
Hi, basically for aesthetic reasons I'm wanting to remove my chainring guard as I personally think looks better without.
I did remove it but noticed a little bit of play as the 5 Allen key screws didn't screw the whole way to tighten completely.But tightens perfectly when guard is on. Can I just purchase 5 of the same screw (nuts) that are shorter in length that will tighten chainring to crank arm securely.
Or would it be best to keep it how it is. Thanks
Deleted member 23692
You need shorter chainring bolts like these - http://www.ebay.co.uk/itm/STRONGLIG...-BIKE-CYCLE-/141555752841?hash=item20f5615f89
Personally i'd leave it on
Mobytek
Need shorter bolts as the longer ones take into account the added depth of the guard.
3 options - shorter bolts, cut off the guard / spacer to keep the same depth or leave as is.
braaivleis2003
braaivleis2003
Derbyshire
Thanks for the link.I appreciate it and totally agree with you on bottle cage. :laugh:. Would it make a difference when re bolting which way the holes are when matching crank arm to chainring, as when I did yesterday after several attempts to get it right, the crank arm would have rotated but the ring was in same position. Hope this makes sense.
