Most people use DIY templates to create there own, I think.
Didn’t see the show but guessing they didn’t get an investment??
I'd seen that, but if not using a front wheel block then it is likely to be fine - I'm not as I have a Flux 2 instead of the Neo, and given that my 63cm frame has a 9mm longer wheelbase than their 49cm frame, I'd not be too worried.There are a few threads on here where people have made their own - certainly much cheaper. the only 'tricky' bit is obtaining the bearings and mounts, but someone will already have a source. At least you can size it up if DIY - the Wiggle reviews mention their model is a bit short for the front wheel and wheel block
That being said I'm not in the market for one, I probably would if I was staying in my current house, but I'm moving and likely to be relegated to the garage when we do, and I doubt I'll be able to ride using a rocker plate in the garage as the roof will be too low - I'm concerned about being able to stand on the pedals without banging my head as it is.
Its great, gentle rocking motion. This depends on the damping method you decide to employ. I use tennis balls(6) with next to none free lean. Others use inflatable inner tubes or other methods.What's the ride like ? I've seen reviews saying it's the opposite angle if that makes sense ?
