1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Specialized Tricross for LEJog?
Discussion in 'Lands End to John O'Groats (LEJOG)' started by memoman, 31 Jan 2012.
  1. memoman
    memoman Active Member
    Tiverton, Devon
    I've been offered this bike for a very reasonable price. Question is, do you think it can do LEJog?
    Thanks
  2. aberal
    aberal Senior Member
    Midlothian
    Certainly. Needs road tyres though.
  3. Norm
    Norm Guest
    It's the closest that Specialized do to a tourer. Given the size of Spesh, if they think it's good enough to fill that space, I'd be happy to say yes to that question. :thumbsup:
  4. memoman
    Tiverton, Devon
    It's got brand new Marathon Plus's fitted.
  5. memoman
    Tiverton, Devon
    Sorry missed something out. We're doing it unsupported. Do you think it'll still be up to it?
  6. wintonbina
    wintonbina Senior Member
    Bournemouth
    Yes to the bike doing it. Don't know about you to pass comment ^_^but if you can master the bloody hills of Tiverton then you will find it a doddle(ish)! Tony
  7. memoman
    Tiverton, Devon
    :biggrin: Thanks for your comments. Will try and snap it up asap!
  8. theloafer
    theloafer Guru
    newton aycliffe
    lejog can be done on any bike ..:whistle: i just prefer my full blown caygill tourer get the gearing right and your half way there
  9. Mister Paul
    Mister Paul Honky
    North Somerset
    I know someone who did LEJoG on a Carrera Subway. So yes.
  10. donnieban
    donnieban Active Member
    Isle of Skye
    Tricross was suggested to me(for LEJOG) by several LBS. Robust, low geared and rack compatible and able to mix it with the best of them.
  11. doog
    doog CRO
    did you buy it? I have a Tricross and have a done a few tours including Spain back to the UK fully loaded. The only upgrade I would recommend is the wheels if its still on the stock wheels ( or at least just the rear wheel if you are on a budget)
  12. donnieban
    Isle of Skye
    I was all set to buy till my employer pulled out of the cycle scheme......
    Ended up buying a 2 year old TREK 520 tourer which seems good but will end up replacing the wheels n drivetrain, out of preference - so almost back to square 1.
  13. gary in derby
    gary in derby Well-Known Member
    Derby
    can you enlighten me as to why a change of wheels?
  14. doog
    doog CRO
    Its unlikely the stock wheels on a Tricross will be suitable for a fully loaded tour. Mine certainly weren't (cheap32 spoke Alex rims). At the very least replace the rear with something stronger, hand made and with 36 spokes.
  15. david1701
    david1701 Well-Known Member
    Bude, Cornwall
    The man has a point if you're carrying a lot of weight, I've kicked mine out of true twice, admittedly both on twisty coastal single track and once with a rack bag over :tongue: but still a weak spot
