2013 Crux Elite Disc. Spec below. Good condition. Only been raced in a duathlon once and mainly used for commuting and messing about in the woods. No bumps or prangs just minor cosmetic scratches. Msg me if interested and I'll send pics. The only changes I've made to the bike is to change the bar tape to black and remove the stickers from the wheels.
Offers around £800.
Frame: Specialized E5 Aluminium disc, fully manipulated tubing, smooth weld, semi-compact race design, shaped TT, 1-3/8 inch lower bearing, internal cable routing, integrated headset.
Fork: Specialized FACT Disc carbon monocoque fork, carbon steerer and crown for 1-3/8 inch lower bearing
Headset: 1-1/8 upper and 1-3/8 inch lower sealed Cr-Mo cartridge bearings integrated w/ headset, 20mm alloy cone spacer, w/ 20mm of spacers
Stem: Specialized CX, 6061 alloy, shallow bend
Speed: 20
Front Mech: SRAM Apex
Rear Mech: SRAM Apex
Chainset: FSA Gossamer BB30 46/37
Bottom Bracket: OS integrated
Chain: KMC X10 CP
Cassette: Shimano Tiagra 10-speed, 12-28t
Rims: Axis CXD
Tyres: Specialized Tracer Sport, 60TPI, wire bead, 700x33c Front Specialized Tracer Sport, 60TPI, wire bead, 700x33c Rear
Front Hub: Axis CXD
Rear Hub: Axis CXD
Front Brake: Avid BB5 disc, 160mm
Rear Brake: Avid BB5 disc, 140mm
Seatpost: Specialized Sport alloy, 27.2mm
Saddle: Nylon flat test ride, loose-ball, w/ reflectors
Offers around £800.
Speed: 20
Chain: KMC X10 CP
Rims: Axis CXD
Front Hub: Axis CXD
Rear Hub: Axis CXD
