[QUOTE 1813148, member: 9609"]You would probably get away sealing it with some diluted PVA glue 6:1 then another coat 3:1. But you should seal it with something! The Acryilic stuff is what you should be using, but I have never seen any problems with PVA[/quote]
Done it twice, that is sealing surfaces with diluted PVA, then tiling. Once I sealed plasterboard (maybe this was not really needed) and once I sealed a freshly plastered wall after about a week that the plaster was applied. In both cases the tiles, years later, are still up
