Which freewheel sprocket do I get for my fixie please?
Rimmer
On a whim I bought a fixie for a good price @ £55 - as pictured - but tbh, I just can't get used to not freewheeling. Now I know I need to simply screw on a freewheel sprocket but are they any size, teeth or quality considerations based on the configuration of my bike?
Could you post a link so I can just get one that suits the bike. (sorry fixies are just not intuitive for me).
Thanks and here are the pics.
Sharky
Kent
Look at Dicta freewheels on velosolo. Cheap and not super quality, but should last a few seasons. An ideal gear is about 68", but depends on your terrain and fitness. If the flip side has a fixed sprocket, then never a worry about fails on the freewheel.
If you use shimano or other high quality ones, you need to be certain on the size you need, otherwise it will cost to keep changing.
Deleted member 1258
Do you have a flip flop hub, fixed one side, freewheel the other side?
Sharky
Kent
Peugeot make a single-speed with a 56 inch gear (36/18 x 28).
https://cycles.peugeot.com/urban/legend/lu01
It's probably best to check how many teeth are on your fixed sprocket and then get a freewheel with 2 less. It will be harder to pedal without the kinetic energy stored in the rear wheel.
I would probably go the other way and use a larger freewheel than the fixed sprocket. My view is you need a ratio to climb the steepest climb on your normal route and for descents, you just freewheel if the descents are too quick.
Chris S
Birmingham
Sorry, that was a typo. I've now corrected it.
midlife
Didn't notice the tensioner, but I can't believe you need one with horizontal dropouts.
Yep, such an odd setup....
Deleted member 1258
It's probably best to check how many teeth are on your fixed sprocket and then get a freewheel with 2 more. It will be harder to pedal without the kinetic energy stored in the rear wheel.
Looking at the website and they're talking about it as a fixed but showing a bike with a single speed freewheel. :eek::wacko: I like it, but I'd want it as a fixed with a bigger gear than 56, my genesis has a 44 x 17 68" gear
All uphill
Still rolling along
Somerset
That looks like a nice frame and fork - Carlton, maybe?
Certainly a good buy so long as that fresh looking paint is not covering up any nasties.
I agree with the other comments that the tensioner shouldn't be needed. Getting rid of it will reduce friction, noise and weight a little.
It looks to me like it's on something like 50/16. If you are strong and live somewhere that doesn't have hills that may be fine, but I couldn't get to the end of my road on that!
For me I'd keep the crankset and put a 19 tooth freewheel on the back.
You may need to apply some serious force to get the old sprocket off!
rogerzilla
A 60" gear works well for a singlespeed. Get one with 1/2.33 times the number of teeth on the chainring (or the closest available).
Sharky
Kent
Same 44x17 on my SS, but a slightly larger 50x14 on my fixed for TT's only.
Juan Kog
permanently grumpy
Can I put in a plea to persevere with fixed , your right it's not easy to start with , there will be a few " heart in mouth" moments, but if you stick with it you'll forget the scary bits and actually enjoy it.
Deleted member 1258
I'm messing about with different gearing at the moment, I had 48 x 19 last winter and going with 44 x 17 for this one, my favourite is 44 x 18.
