mickle
innit
- 53.933606, -1.076131
My bakfiets came with an pair of Shi**no Inter M (IM40/1) hub brake. The rear is poor but the front is truly pathetic. Little power and zero feel. Maximum power comes after about twenty mm of pull of the original (and correct) lever - and then it goes all the way to the bar. I have the option of retro fitting a V brake mounting plate but it adds complexity, cost and weight when all I want is the existing brake to work. I tried a different, used but otherwise identical IM40 front and replaced the cable. There was no discernible change.
I've recently discovered that these brakes have Shi**no's notorious power modulator (it certainly feels like one). Which I understand in this system is a kind of slippingclutch mechanism. An expert in these matters has suggested a more up date IM80. But if the clutch is, as I suspect, within the hub rather than the brake mechanism the most up to date, most powerful brake in the universe wont make any difference.
Others claim that these brakes perform faultlessly on cargo bikes. WtF is going on? I have no desire to replace the hub - which seems to me to be the only option if I want it to work. The V brake plate is a last resort.
Will a new (£40+) IM80 fix the problem? If the power modulator is within the hub is it possible to disable it?
Any ideas - before I crash into something?
I'm tempted to dismantle it....
