Cycle Chat Cycling Forums: stem removal - Cycle Chat Cycling Forums
Jump to content
To enjoy CycleChat without adverts - Register now - it's free and easy!
  • (2 Pages) +
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
stem removal Rate Topic: -----
#1
User is offline   Panter
  • Just call me Chris...
  • View blog
Sorry all, silly question but I thought it may be more appropriate here than in beginners.
To remove my stem I assume that I first need to remove the cap thing that sits on the headset ?
If I unscrew that allen bolt, will the cap thing simply lift off so I can then undo the stem bolts and slide that off next? or will springs and washers and things fly out and be lost forever as so often happens when I get to close to a spanner :D
#2
User is offline   Elmer Fudd
  • Executive Member
Should be :-
Take the cap off, undo stem, slide off.
Dont know what happens if you pick the bike up whilst doing that though (forks fall out ????)
Take it you are trying to change stem height ? Which road have you gone for ? adjustable or just flipping current stem or 'borrowed' the other stems off your mate ?
#3
  • View blog
Thanks Elmer :roll:
This is just the first quick fix of flipping the stem, I'll leave the bike firmly on the ground then :D
#4
User is offline   Steve Austin
  • The Marmalade Kid
stem bolts first. top cap 2nd. to undo it.
to tighten back up
topcap 1st. stembolts 2nd
#5
  • Executive Member
to tighten back up
Quite right, i was just thinking on how you attach it :D :roll:
#6
User is offline   Mister Paul
  • Born Under a Road Sign
And remember that the top cap doesn't need to be really tight. Just enough to keep everything snug.
#7
User is offline   bonj2
  • Guest
not only doesn't need to be really tight, shouldn't be really tight, otherwise it will bugger the star fangled nut.
#8
  • View blog
Thanks guys, much appreciated :roll:
Well, that was laughibly easy. It's given a slight lift to the bars, i've also rotated them slightly more upwards so i'll see how it goes.
Quote
Quote
(Sneaks back into shed and slackens off firmly tightend top cap :D)
Thanks again :roll:
#9
  • Guest
Thanks again :roll:
it'll be ok now, but for future reference if you have tightened it really tight and it hasn't broken the star fangled nut, then it'll be ok - it won't break as you ride. It's only likely to break as you're tightening it. But I've once merrily tightened it more and more and eventually heard a groaning cracking sound and it became really loose and free.
#10
  • Guest
dan bo might have a copyright on that avatar you know.
  • (2 Pages) +
  • 1
  • 2
