Just was wondering a few totally random things.
1- Should the front gears be set at the highest possible or lowest, or it doesn't matter. assuming same ratio.
For example if set the front gear set to 3 back gears set to 4. Or front gear set to 2 and rear gear set to 8 and assuming that was the same ratio is there a difference in how easy it is to push the bike forward
Hope i've made that clear. I always assumed it was the same but thought i'd ask.
2- I've just started commuting 8 miles to work. I'm doing it in about 45 minutes on a mountain bike with slicks in London roads. how fast can you guys do 8 miles with same setup.
3-how useful are the pollution filters.
4-I bought a cheap argos helmet for £8.99, what advantages in terms of safety would getting a more expensive one be? or is it just a comfort difference?
5-any recomendations for a pump that i can use at home to get to 80 psi without resulting in RSI, but can also be carried about. for about £20.
I appreciate the help.
