Absolutely that. Steep hills can reduce my speed to around 3-5mph, and I only need a few miles of that to add a considerable time to my total....climbing disproportionately extends the time required to do a given distance...
Does anybody know how I can get the gradient of the route. Ride with gps doesn't look like I can gather info
Are you using a PC to map the route? On mine I go into the route, and on the right hand side there is a panel that tells you maximum gradient, and the elevation profile tells you the spot gradient as you move the mouse over it.
How do you mean "the gradient of the route"? RWGPs should give you the total ascent and distance (edit: and average gradient in the "metrics" tab) and when you position your cursor on the elevation profile at the bottom (when in view mode, not edit mode) it will show you the gradient at that point. Or you can drag and highlight a bit of the elevation plot to zoom in.
Edit. And when you do select a bit in the elevation plot and zoom in (a particular hill maybe) the "metrics" tab will show you the average gradient for that hill.
Well you could have learnt your lesson after the first year!It is very easy to get caught out by average gradients over a certain length of road. I took a quick look at the climb from Flint on @nickyboy's Llandudno ride and concluded that it seemed easy enough to tackle on my singlespeed bike ...
There are a few fluctuations but it looks okay, doesn't it?
But in reality it was very hard on s/s! Take a closer look ...
When you take an even closer look you will see ramps of 8.5%, 7.7%, 12.0% and 9.4%. Not killers with 20+ gears to choose from but leg-shredding in a 52/19 gear!
I DID learn my lesson, so I intended to go the flat coastal route. For some reason, I thought that the cycle path started at Flint but I overheard nickyboy saying that there were miles of A-road to ride along to get to it, so that put me off!Well you could have learnt your lesson after the first year!
Well. I went out last night for a 50 miler to test the water a bit and to be honest, the last 10 were a bit of a slog. I couldn't imagine doing that twice over with a lot more hills. My elevation last night was 2500ft which is just over a quarter of the Exmoor route. I know I'm not ready yet. I'll do a couple of 75 miles in the next few weeks and then choose a relatively Flatish route around by me.
Thanks again though for all the good advice. I will use it soon.
A wise decision. Onwards, and upwards ... just a little more slowly!Well. I went out last night for a 50 miler to test the water a bit and to be honest, the last 10 were a bit of a slog. I couldn't imagine doing that twice over with a lot more hills. My elevation last night was 2500ft which is just over a quarter of the Exmoor route. I know I'm not ready yet. I'll do a couple of 75 miles in the next few weeks and then choose a relatively Flatish route around by me.
