I've been turning an old gas pipe special into a winter fixed gear and aiming to keep it as cheap as possible. The components of the bike are all perfectly useable and have only needed a re-grease and some new cables. I have an old 46 tooth chainset, I was happy to live with the chrome wheels so I thought the only parts I needed to buy were a tracksprocket, chain and brake cables/blocks. I have now discovered that the thread on hub doesn't have enough threads for both a track sprocket and the BB lockring which I had intended to fit.
Does anyone ride without a lockring or will the sprocket just unscrew. I will be running a relatively low gear but don't do skid stops or any heavy leg braking. I generally only leg brake in controlled situations like losing speed on the approach to a junction. I will have brakes back and front for anything else.
