Avid Juicy Disc Questions..
Mark999
The first of many silly questions!
1) When I remove a wheel, is the little red plastic 'key' type thing that came with my bike, for placing between the brakes so they do not close together?
2) How do I tighten (firm up) the brake levers so that they do not need pulled as far?
Avid Juicy 3 hydraulic disc brakes...
Thank you folks
Mark
summerdays
Cycling in the sun
Bristol
Answer to question 1 ... yes - it is to stop either your son pulling them on and telling you they don't work or you forgetting yourself and pulling on the lever and then lots of swearing ensuing :whistle: - I've had lots of practise at not using the red thing and if you are like me I highly recommend that you do.
No idea about 2 - sorry :biggrin:
M
Mark999
Thanks - one out of two ain't bad
Oh, I have a son?! That sounds like something I should have known about ;)
summerdays
Cycling in the sun
Bristol
Well in that case if the lever gets pulled you will only have yourself to blame!!! At least I can blame someone else :smile:
subaqua
What’s the point
Leytonstone
aaah so thast what the red thing in the bag with rock shox stickers in it is !! i just never pull the levers and keep the youngest monster away from the bike when the wheel is off.
i had an expensive incident with car brakes many tears ago and learnt a valuable lesson.
Avid Juicy's are a bit softer at the lever than many hydro disks. A good bleed with levers absolutely horizontal so the air can be pushed out of the master cylinder on the lever can get them temporarily a bit firmer, but they are never going to be the on\off switches that some brakes are.
They did stop the bike just as well as my Auriga's but had a more squeezy feel, so personally I liked them.
potsy
Rambler
My Armchair
I realise it was upsetting subaqua, but there's no need to cry about it
M
Mark999
Ah, great to know. Thanks. I'll leave them as they are. Just thought they 'needed' firmed up, but I stand corrected.
Bleeding the breaks - I am aware they need it now and again, but I have not done it yet (only 6mths old now). I'll go away to try to find an article on this. Interesting indeed, thanks.
Is there any symptom that indicates the breaks need bleeding? PResumably, the same principle as bleeding car break fluid now and again? The fluid just needs refreshed and replenished? Not even sure what type of fluid it is.. I need to find that out first I guess!
Cheers
