Brake caliper
jowwy
Can't spell, Can't Punctuate....Sue Me
Call me thick here
but whats the difference between a front and rear brake caliper??
i have a sram rear caliper - want to know if i can put it on the front
accountantpete
Brexiteer
Just the length of the central bolt - the front has to pass through the forks and so is a bit longer. Your rear won't fit unless you have one of those long nuts.
J
jowwy
ok
on looking at my front forks - the stud doesnt go all the way through it - it seems to be recessed at the back of the fork and the fixing bolt goes inside
might see if it will go in tomorrow
One solution is an extra long back nut.
J
jowwy
just did some fettling and the front bolt doesnt come through the forks enough to fit the fixinf bolt onto - so did a bit of fettling and now my brakes are running pretty sharp
will go for a spin in the morning to check them out me thinks.....but not to early its cold tmrw :cold:
