SteveCon99
- RH17 5PG
I've been commuting with my Brompton for over a year.
I love the bike but recently I've been driven mad with creaking sounds when I pedal hard :
Just want to share what I did to eventually find the source :
Creaking only happened when pedaling hard.
Creaking happened when I pedalled standing up, so not saddle or saddle post issue.
Greased the internals and other rubbing surfaces of the suspension block : no difference
Lubed chain and got some oil into pedals, no difference.
Check that both crank bolts were tight and there was no play.
Replaced both pedals with some spare ones : no difference.
Replaced chain for new one : No difference.
Tried pedaling without the chain on. Bottom bracket appears perfect, no play or roughness, no creaks either.
Removed suspension block and inserted a wad of paper, pushing down on the frame made the creaking noise !
Squirted some thin lube/water-displacer at the nylon washers of the rear triangle hinge.
At last success , no more creaking !!
Happy cycling.
Regards
Steve
Happy cycling.
Regards
Steve
