willem said:I did on Ryanair to Stanstead. The rack got bent and the so did one of the two studs on the frame for the little wheels. I have since seen many Bromptons with the same bent studs, and I now realize these are vulnerable.
Willem
Crankarm said:Could a Brommie not fit in a hard case to avoid damage? I have a Brommie bag but I suspect it would offer little protection to bike when the baggage handlers are chucking it around .
Ha!Bokonon said:it seems that current advice is to pack standard bikes in a transparent cover and then the baggage handlers will be more careful with it...
ColinJ said:Ha!
I packed my new Bianchi in a bike bag for its first flight. Okay, it wasn't a transparent bag but the bag had large pictures of a bicycle either side so the handlers knew what they weretrashing, er, handling.
Being the cautious type, I'd put a cardboard bike box inside the bag and the bike inside the box. I'd put pipe lagging on the frame tubes and forks, and filled any empty spaces with bubble-wrap to stop tools and other things bouncing about. If that little lot didn't protect my bike, then I was a Dutchman's uncle.
Call me Jan...! There I was in a plane at Alicante airport, peering out of a window while waiting for permission to disembark. Oh look, there goes my bike bag flying through the air! The lazy buggers had only chucked it about 6 feet down from the baggage hold onto a pile of suitcases.
When I got to the hotel, I discovered that my new £1,000 frame had a dent in it! Years late, the frame cracked where the dent was.
After that I spent over £300 on a SciCon bike box. The handlers have managed to drop that on one corner, cracking the case and breaking a wheel off but my bikes have survived another 6 or 7 return flights since then.
Bokonon said:There is then the problem of transporting a hard case to/from the airports. I'd agree with the view that the Brommie bag would offer no protection, but it seems that current advice is to pack standard bikes in a transparent cover and then the baggage handlers will be more careful with it...
Well, all I can say is that I have been flying with my bike every year since the early 1980s and I have never had it damaged in any way. I do the minimum packaging that the airlines allow, so to start with it just went bare, then in a plastic bag and now in a soft bag.Crankarm said:I bet baggage handlers instantly realise the package is a bike and try to do as much damage to it as possible by "innocently" chucking it around so as to discourage anyone from ever taking a bike with them again when they fly. I wouldn't be surprised if this was standard unwritten air line policy across the industry.
SavageHoutkop said:Depending on the hand-luggage rules you may be able to carry it as hand luggage.
