swee'pea99
It's steel (the frame) if that makes a difference.
Yep. I've been running a 120mm wheel in a 135mm frame for years. If you're using chain tugs will they be about the right thickness to use as spacers if you put them between the wheel and the frame?
Nice picture. Are the dropouts track-ends or horizontal? Do you have a weblink for those chain-tugs?
Track-ends (based on Sheldon's photos) (It's a Pompino). The chain-tugs are years old, they're branded Diamond Back and I bought them from Halfords They're not these, but they're very similar - On-One Chain Tugs
Add a few 10mm washers between the cones and locknuts. I would go down this route even if it meant buying a longer axle. If you just squash the frame in, the dropouts won't be parallel.
