cells inside a 36v 13a battery help please
billym0404
durham
so i keep looking inside battery's. now as i understand it using 3.7v 18650 2600mah cells. i should use 10s5p setup. so 50 cells. every picture i look at of a 36v 13a battery even though it says 10s5p contains more than 50 cells
every one i look at is like this, so what am i missing please. wht do all the ones i look at contain more than 50 cells. ass you can see by the picture this on contains 55 cells yet it says
36v13ah(10s5p 18650 2600mah )
help please
Ajax Bay
East Devon
10 series (ie giving you 37v nominal) and 5 parallel (giving you a capacity of 5 x 2.6Ah = 13Ah). Perhaps they're not confident of achieving 3.7v in all the cells (and there'll be connection losses) so 11 x 3.7 allows for that and to make the spec with assurance. There's a fair bit of variation in medium quality 18650 batteries and a steady (though very gradual) drop-off as the battery pack is in use. If it's a couple of volts over the motor will be entirely content. If it's under 36v, motor will be less 'happy'.
HTH
screenman
Out of interest how are you going to solder them all together, I have tried in the past without success, as for getting the factory tabs off that was not an easy one either.
