DrSquirrel
Firstly, I have a FSA Gossamer (triple) with 105 (external) BB.
BB was creaking a bit, so I stripped it down (first time for me), cleaned it up (bit of water got in), greased it all up and put it back in - no problems and no cross threading. I put the drive side crank/shaft through - little tight so enticed it in with a block of wood, and put the opposing crank arm on... the drive side wasn't fully on so I used the "dust cap" to pull the cranks together.
I have no idea what it is, so I will call it "dust cap", its the same as the smallest item in this pic.
Firstly - it worked, I was using a small ratchet and it didn't take much effort. BUT - I stripped the head, what is worse the crank arms don't seem to be turning so freely by hand. When riding its not so bad, but the idea that the drag is there troubles me.
Can I overtighten the "dust cap"? Any ideas on how to remove it?
