Origamist
A bit more info about the Super-Highways.
Mayoral Q&A:
*101** / 2009 Cycle Super-Highways*
Could you expand on your plans regarding the 12 cycle super-highways and
where these will be built?
*Joanne McCartney*
Cycle highways will be a set of twelve high-profile radial routes into
and out of Central London that will concentrate cycle flows and provide
a fast and efficient way into the centre.
TfL is currently working on the definition of the specific routes; it is
expected that a more detailed announcement will be made by the Mayor in
Spring. This will include information on the implementation of the first
routes and associated package of measures.
Cycle highways will comprise a package of innovative measures, including
information along the route, to encourage people to cycle. They will
also include engineering interventions where necessary.
Due to the nature of the road network, Cycle Highways cannot be a
'one-size-fits-all' solution; however, they are likely to be based on
the following basic principles:
· *** Safety*: All routes will include safety measures. These
may include traffic calming measures, enforcement and advance stop
lines among others.
· *** Directness*: They will follow direct and reliable
routes into Central London with clear information on cycling time
to destination provided.
· *** Continuity*: The whole route will be clearly marked
from beginning to end.
· *** Visibility*: Each route will have a clear identity--
e.g. 'Docklands Cycle Highway' or 'Northern Line Cycle Highway',
with consistent and easy to follow road markings and signs.
· *** Comfort*: Road surface conditions will be improved and
obstructions will be minimized.
· *** Value for Money*: To make best use of existing
resources, cycle highways will concentrate on pragmatic and simple
measures and will not depend heavily on engineering
interventions.
Mayoral Q&A:
*Joanne McCartney*
lines among others.
interventions.
