Excel Help
Brains
Greenwich
Data
Sort
Select values
A B
1 £5
2 £4
3 £3
You either have it sorting the data by the value of col A or the value of col B. If you want both at the same time you feed the data from this table to a new one sorted by whatever value you want.
If your rows are not numbered apart from the Excel row number then you can make a new column with the value in the box being 1 and then each box below being +1. Then the values of this col can be sorted too.
