terry_gardener
- stockton on tees
i took the bike for it 1st service today and received not very good news.
the problem that i posted about before where the rear tyre wouldn't pump up greater than 110psi due to rubbing on the frame behind the frame. when i contacted wiggle about this they said it was either the tyre not seated properly or the rim was slightly out of alignment.
however the local bike shop has had a look and stated the wheel and tyre are fine but the problem is the frame it just doesn't have the clearance to allow the tyre to be pumped up that far, and stated to contact the seller which in this case is wiggle and get them to supply a bike that there is sufficient clearance for the rear wheel to be pumped up greater than 110psi and this could cause more problems in the long run.
so it looks like verenti have created a bike that when you get the smallest size doesn't have the clearance required, sounds like a great manufacturing defect to me.
i have emailed wiggle to see what they say.
