Forum Upgrade
Shaun
Founder
I've upgraded the forums this evening.
So far it looks like most things work, but there are several new settings and template changes, so if you notice anything unusual or something doesn't work like it used to - please let me know.
Thanks,
Shaun :eek:
TheDoctor
Europe Endless
The TerrorVortex
The Quick Reply box seems a tad more cramped than it was. Unless I've put some weight on, which is not unlikely...
*gets another chocolate cookie*
Shaun
Shaun
Founder
Still crawling through the master board settings and new features ... I'll sort this shortly. :eek:
Shaun
Shaun
Founder
If CC looks a bit different at the moment, it's because the upgrade removed some template modifications I'd made.
It's too late to start re-hashing templates, so I'll have another look tomorrow night.
The quick-reply is now back to normal, but again, if you notice anything that isn't working how it used to - please let me know.
Thanks,
Shaun :eek:
summerdays
Cycling in the sun
Bristol
I take it the name of the original poster used to be in a column all on its own and now it appears underneath the post title... this had me confused for a bit when I opened a post to find it wasn't by the person I thought it was. I didn't even realise that I took in the name when I was opening a particular thread. Once you get used to it I don't see it being a problem.
Shaun
Shaun
Founder
I'll hopefully have this back to normal after I've been through the templates this evening. ;)
You also can't view other peeoples profiles now. You just get some PM options.
Is it me or does everything look a little paler?
Shaun
Shaun
Founder
Crackle said:
Forum jumps gone as well I think.
These should return once I re-work the templates.
Crackle said:
Not keen on the underlined titles but I'll get used to it.
This is related to the forum CSS which was overwritten during the upgrade. This, too, should be rectified this evening. ;)
