dataretriever
- NW London
Ok, I reattached the cable to my front derailleur after reassembling the trice Q and now the front change is wonky. I couldn't make it work so took it all apart and started again:
but now the shifter turns to click 2 but misses the middle ring altogether and goes straight to the big ring. Click three chucks it off the edge.
I've reset the adjuster screws and checked the cable tightness and all seem fine, I just can't adjust it to get it working on all three rings at the proper clicks.
My 2007 Q is running campag rings, a no name front Derailleur, microshift shifters, suntour sprockets and a shimano deore rear derailleur. I guess the mix of kit isn't helping but it did work fine before.....
Is it worth going for SRAM shifters and derailleurs front and back? or should I resort to the LBS?
I'm a competent bike tinkerer but this has me foxed.
- I've placed the derailleur 2-3 mm away from the big ring and made sure it was parallel to the rings.
- Set the inner adjuster to set it 2mm from the chain on the small ring
