When I brake hard on my hybrid and my weight goes forward, I've noticed a slight jerkiness in the bars. It's as if the bolts at the front of the stem are a tiny bit loose so there's a little play when the bars are under a lot of force.
I'm intending to swap the stem anyway (a new longer one arrived this morning), so if that is the cause then it won't be for much longer. But is there anything else I should be looking out for?
I know creaks and clicks usually end up coming from the last place you look, so I just thought I'd check if anyone else has experience with this.
