Sorry, I am sure that a similar problem has been posted before but when I search for info on headsets I end up with far too many results to look through.
I have an issue that I can't get my setting for my headset just right - it either works itself loose or, if I tighten it enough so that it doesn't loosen, it becomes too stiff to turn.
Initially I could not get it tight enough and it was always clunking. I did about 50km of on-road riding on it that way until I worked out that the spacers were only about 1mm above the top of the steerer tube. I cut off 5mm off the steel steerer tube with a pipe cutter (to make sure the cut was even) and now the lip of the top spacer lies about 6mm above the top of the steerer tube - so there is enough room to press down on the spacers.
However, when I tighten the top bolt down to make sure that there is no play in the headset, i usually have to tighten it so tight that it is very difficult to turn. I tried riding it that way for a short period but quickly realised that if I continued, sooner or later I would not be able to turn to maintain my balance.
If I loosen the headset any little bit from being very tight, then immediately there will be some play. I've ridden it this way but find that the play gradually gets worse as I ride the bike and I have to retighten it fairly often.
Whenever I make an adustment, I loosen the fixing bolts to the stem as well and tighten them back after adjusting the headset.
It is a Richey threadless type headset using cartridge bearings. The forks, frame and bike are brand new. The frame and forks in the same box but not attached to each other. The lower crown race was attached to the forks and the headtube races already attached to the frame. A star fangled nut was inserted into the steerer tube by my LBS. The steerer tube is made of steel.
I am now wondering what i the worst case and best case scenario here. Might it be fixed by cutting the steerer again (I have about 2cm of spacers above the stem which I can play with)?
