Hi folks - i have a 2007 langster in the much loved 'rust' colour (no laughing at the back - i like it - thats all that matters!)
it currently has standard gearing - which is the sugino 'comp' chainset with a cnc 'zen' 42 tooth chainset with a 16 tooth fixed cog at the back.
ordinarily this would be fine - but i've buggered up my left knee and need arthroscopy on it to repair / remove a torn meniscus (cartilage injury). I've been advised by the consultant that I can continue cycling if it doesn't cause any pain - which so far seems to be ok - with the proviso that I "don't go daft with it.." i have a surgery date of the 10th of July which seems ages away and if I don't cycle I will turn into a fat bloater.
anyway - i've been avoiding the fixed due to the lack of gear changing since I found out about the injury bu I really miss it so I was thinking of lowering the gearing. I'm not sure though on the technicalities
- is the sugino comp a 130BCD chainset or is it a 'proper' track 144BCD?
and also what would be the bet way of lowering it a little - increase the sprocket to an 18 or 19 tooth? - or go to a 40(ish) chainring?
Any help appreciated - even if you just think I should leave the fixed alone for a bit... :-(
thanks
graham
thanks
graham
