Not happy
Dunlopdave
Horley,surrey
Hi all
Picked up my new cube nature yesterday took it out today for a long ride and it keeps changing gear on its own (it nearly had me off a couple of times) spoken to LBS they said to take it back and they'd sort it which is good but I see a lot of threads on here saying don't use Halfords etc support your local bike shop.Its a good reputable shop with three or four branches and I like the lads in there but for £600 notes for brand new it should be right.P S it got covered in crap what's the best way of getting it back to how it looked this morning without paying somebody else to do do it ????????
Mugshot
Cracking a solo.
Are you saying you bought it from your LBS and your LBS have said take it back and they'll sort it? If so I don't see the problem sorry, what have Halfords got to do with it?
Wipe it over with a cloth yourself, you wont have to pay anybody then.
Dunlopdave
Horley,surrey
Yes I bought it from LBS and 2nd I was just wondering if there was any good cleaning prods out there that won't scratch the paint job when I take the crud off
potsy
Rambler
My Armchair
If it's very muddy then a hosepipe and a bucket of water with car shampoo is best, if it's not too bad then a few baby wipes should be enough.
Gear changing is probably only a half turn of the barrel adjuster, but you are right in it should have been set up correctly when it left the shop (you expect the cables to stretch after a few hundred miles though)
Mugshot
Cracking a solo.
Depends how bad it is I guess, I generally find wet wipes or some soapy water is enough, Muc Off seems to be well thought of though.
Mugshot
Cracking a solo.
It should be yes, but would it make a difference if the bike had been test ridden or not? The gears would react differently with a bit of resistance than they would do on a bike stand wouldn't they?
G-Zero
Durham City, UK
Hi all
Dave,
My Cube was exactly the same last week, gentle ride home from the LBS and everything was fine, but as soon as I got it out on a proper ride, same problem at the back.
As suggested already, a bit mess about with the thumb wheel adjuster soon sorted it and it's been ok since.
