Karlie
- Gosport, Hampshire
Have had my S2 for six years, but from early on noticed problems with the raw lacquer finish. I initially noticed what appeared to be rust spots appering on the swinging arm, on the steering column and under the bottom bracket. Brought this to the attention on Brompton who basically said this was part of the ageing process on this sort of finish, but were prepared to replace both the swinging arm and the steering column. I now have rust developing on the main tube and it looks as if the finish has been chipped though this is impossible as it is road side up and there is no way that road debris could have done this. I get the impression that Brompton feel they may have a design fault with this sort of finish but are not prepared to admit it. Im supported in this view by the fact that Brompton slightly changed the raw lacquer process a couple of years ago in order to avoid the problems they had with the earlier models. Anyone else had the same experience? Do I have a case to argue that Brompton should replace the entire frameset?
