I was given this bike by my dad. As I've mentioned else where it was originally a Record Sprint with Aerospace tubing. He resprayed it and had extra bottle bosses (I don't know why) and the rear centre pull hanger added, oh and the braze on front mech boss had to be repaired too.
I've changed the bars from drops to straight which are ok'ish and now I want to convert it to a single speed/ fixed, I'm not sure which.
I was debating semi restoring it back to Record Sprint origins but working out the cost of powder coating and decals I might as well just get a replacement frame. Anyway for now I just want to cheaply convert it.
The one problem I have with a fixed conversion is that the drive side dropout is not elongated meaning that I wouldn't be able to get the chain tension. My only option here would be to hacksaw and file the dropout to make it suitable.
So the plan is to get rid of the gears keep the 36 inner chainring and have a 14 tooth on the back. Replace the centre pull brakes for something a bit more modern and neater (anyone have anything in their spares box? Nut fitting).
My questions are:
1. The bike has a freewheel (not cassette) what do I need to convert it? My research tells me just a cog, chain, respace the wheel and have it redished. Should I also convert to a solid axle? What thickness chain should I use?
2. How narrow can I get away with cutting the straight bars down to? They're far to wide at the moment.
I think that is all I need to know, for now...
My questions are:
