Angelfishsolo
A Velocipedian
- Cwmbach, South Wales
Well, there we are then. When you say "it's wrong because it encourages copycat behaviour", it turns out that the copycat behaviour is only a problem because you've already decided that it's wrong for other reasons.
I would happily concede that we all need to think about the example we set when we indulge in potentially dangerous behaviours that others might copy - but these behaviours might also include filtering, or riding fast, or riding on busy roads, or riding without hi-viz, or even riding bikes at all. Or crossing the road. The only reason you have for singling RLJ out from these others is that you have already decided it is (in general) wrong and they are (in general) not, but you can't use "it encourages copycats" as a reason for it being wrong, because that's simply circular reasoning. Stick with the good reasons (which so far imo are that it reduces your predictability on the road because you're not following the conventions for road use enshrined in law) and consider the copycat issue as merely an intensifying factor
I have not already decided anything. The law of the land has decided.
I have singled out RLJing as it is the only item listed that is illegal. I'm sure you already know this however..........
