rim tape
Scilly Suffolk
After having two different types of tape fail recently, with the tube pushing through into the spoke holes, I'm after recommendations.
Thanks.
YahudaMoon
The French cloth type. Can't remember the brand name ?
YahudaMoon
Velox
Scilly Suffolk
Scilly Suffolk
Thanks, I'll get some Velox then.
I'm just a little surprised as I assume that cloth tape is older than the plastic type and the trend in pressures is up.
lulubel
Malaga, Spain
Thanks, I needed to know that too.
The tape in my old wheels is cloth, and I never had any problems with it running at about 110psi.
YahudaMoon
The best wheel builders use it. Well the ones I use anyway.
It's only about £1 - £1.50
Won't plastic rim tape have more chance of keeping water in the rim / clothe have more chance of drying out ?
GrasB
Nr Cambridge
Plastic is preferred with modern deep section rims as velox is a one time application. With deep section rims & concealed nipples (racing cyclists are starting to get conservative, lone gone are the days we flaunted our nipples :laugh: ) that means a new rim tape every time you true the wheel.
2PedalsTez
I used plastic tape for a while. I could never figure out why I was getting so many punctures, then went back to Velox and problems went. It might be seen as old school, but it works. :thumbsup:
