Cosmicned
- Swindon, Wiltshire
SOLD!!!
Felt 55cm QX95 2010 hybrid for sale in good condition - used for daily commutes of 10 miles for six months - with nearly new Continental Travel Contact Reflex 700c x 37c Tyres - original tyres un-used & included. These retail around £1000 - thought I'd show it here before I bung it on FeePay... only selling as now preferring a road bike...
Offers...? Buyer collects from Swindon Wilts...here's the blurb...
Go from road to dirt without missing a beat. With a lightweight double-butted aluminum frame and quality, dependable parts, the QX 95 is built for adventure.
Comfortable, versatile and easy-to-ride bikes that offer the durability of a mountain bike blended with the efficiency of a city bike. The QX series is ideal for weekend trail rides, unpredictable commutes or any excursion that might lead you off the beaten path. With lightweight butted aluminum frames and sturdy, reliable components, QX bikes help you enjoy the ride, wherever it may go.
- WEIGHT: 24.02lb/10.92kg
- FRAME: Felt Cross Design 6061 Double Butted Aluminum. Semi sloping Hydroform TT, A Style Seatstays and Chainstays. V and Disc-Brake Compatible, Integrated Kickstand Mount, Basta Lock Compatible
- FORK: Felt Carbon Fork 1 1/8th Alloy Steerer tube and Crown Carbon Fiber Legs, V-brake bosses and Fender eyelets.
- HEADSET: Semi-Integrated 1-1/8" Aheadset--Steel Cups, Caged Bearing, with Alloy Laser Top Cap, Custom Curved 1 x 15mm + 2 x 5mm Straight Washers
- STEM: Felt One-Piece 3D Cold-Forged + CNC, 1-1/8" Threadless Aluminum, 25.4 Bar Bore, 4-Bolt, 5 Degree Rise. Extensions: 44cm=80mm; 48/49cm=90mm; 52cm=100mm; 55cm=110mm; 58cm=120mm
- HANDLEBAR: Felt 6061 Alloy butted Flatbar 44cm/48/49/52cm= 580mm; 55/58=600mm With Forged "Shorty" Barends
- GRIPS: Felt Ergo Grip Dual-Density Extra-Soft & Sticky center with Hard Outer Durometer, 130mm Length, 30mm OD, Grey outer/Blk grip section
- BAR ENDS/CAPS: Rubber Plugs w/Felt Bubble Decal, Included w/Grip
- SHIFTERS: Shimano LX Trigger Shifter, 27 Speed
- FRONT DERAILLEUR: Deore LX FD-T661
- REAR DERAILLEUR: Deore LX RD-T660
- CRANKSET: Shimano LX FC-T660 Hollowtech Non-Series Forged Aluminum, 2 pc design 48/36/26T Aluminium Outer, Steel Middle/Small Rings, 9-Speed, Chaincase Compatible, With Chainguard, Lengths: 44/48/49/52cm=170mm; 55/58cm=175mm
- BOTTOM BRACKET: Shimano LX Included with Crank
- PEDALS: VP-199 MTB Design Alloy Cage / Alloy Body, Toe Clip Compatible, Silver / Black
- CHAIN: Shimano HG-73 (9-Speed) Silver outer
- FREEWHEEL/CASSETTE: Shimano Deore CSHG80 9-Speed 11-32T CP finish sprockets
- BRAKE LEVERS: BL-M660 design 3.5 finger level
- BRAKES: BR-M660 V-brake design
- CABLES: Felt Custom Cable Set Black casing, Featuring CP Stamped Logos & FELT Rubber 2-Tone Tube Tops at Head Tube
- SADDLE: Felt "RXC" Race, Super Low Side Profile Look with Medium/Flat Top, Double-Density Base, Tubular Cr-Mo Rails
- SEAT POST: Felt Two-Bolt Alloy Micro-Adjust, 100% Black, 27.2x350mm
- SEAT POST CLAMP: Felt Bolt-Type, Cold Forged + CNC, 6061 Aluminum, with Steel Barrel Nut Design, 31.8mm
- RIMS/WHEELSET: WTB DUAL DUTY XC lightweight doublewall, Black Anodized CNC sidewall, 36 Hole
- FRONT HUB: Shimano Deore LX HB-T660, 36H
- REAR HUB: Shimano Deore LX FH-T660, 36H
- SPOKES: Stainless Double Butted 14G/15G Black Brass nipples
- TYRES: Felt Cross Design 700 x 37 120Tpi with Folding Kevlar bead
