Rob3rt
Man or Moose!
- Manchester
For sale:
wethepeople Reason '09 BMX bike
Blurb
Used as a commuting machine over my very short commute as an undergrad for a month or two, having quickly found it to be inadequite for anything it was leaned up against a wall in my room for about 3 months and since then its been stuck in my office for about 18 months gathering dust. Never been used to pull tricks, barely used at all really, I'd guess its done about 40-50 miles. The inner tubes may have a patch or two, the rear has been patched, cant remember how many times, but can remember two specific occasions that I patched it.
Full spec
Frame: CrMo downtube and a 1020 Hi-Ten, 20.4 inch top-tube
Fork: CrMo Steerer
Chainset: Salt Tubular 3 piece Crank. CrMo 175mm
Chainrings: 28 tooth sprocket
Bottom Bracket: Salt Mid Size BB sealed Bearing
Cassette: 10 tooth 1-piece Cassette Driver. Loose ball type
Chain: Salt AM S410H
Pedals: Odyssey Twisted PC Pedals
Rear Brake: Salt Alloy U-Brake Rear
Brake Levers: Salt Alloy Brake Lever
Handlebars: 1020 Hi-Ten Steel with a 7.6 inch Rise
Stem: Salt Alloy, Front Loading Stem, hollow
Headset: Salt Int. HeadSet (Cartridge Type)
Grips: WeThePeople Rhombus Grips
Rims: 36 hole Salt AM Rims
Front Hub: Salt loose ball 3/8s 36 hole
Rear Hub: Salt Cassette 10 tooth loose ball type
Front Tyre: Kenda K-Rad 2.125 inch
Saddle: WeThePeople Slim Seat 8mm Rails
Seatpost: Salt 25.4mm x 180mmAccessories:
Salt AM steel Pegs 1 pair (comes with 2 pairs of pegs, I got a second pair at point of purchase, they are demolition branded)
Weight: 12.2kg (26.8lbs) approx. Without Pegs
Has a couple of slight dings from a failed lean against a wall at the local post office. Sticker on seatube reading Shoshin is a sticker of a mates band, can be removed without any marking and residue easily wiped off (I had some on my fixed bike, since removed with no trace).
Price: Im looking for something like £130 for it but am open to negotiation (I'd really like the office space back). Will post it within the UK, postage cost to be agree'd with the buyer (depends on prefered method and associated costs etc).
Blurb
Full spec
Fork: CrMo Steerer
