sold ; SRAM Shifters/ Rear Mech Bundle
accountantpete
Brexiteer
Go Sram for £55.
Basically your existing 10speed Shimano chainset/front mech/brakes combo will work equally well if not better.
All you do need is the shifters and rear mech.
So for £55 posted you get a pair of shifters - Right Apex lightly used (with a couple of scratches to the lever which black paint will hide) and Left Rival (well used but fully working) with carbon lever (this has a slight repair as it lost a little washer which holds the paddle proud of the lever so I have put a bit of plastic in it's place which does the job ok - even without this the lever would still work ok). The left Hood has a hole in it on the side which can be left or repaired.
Also a slightly scruffry Sram Force rear mech with Tacx steel ball bearing Jockey Wheels.
Levers and Mech sold
@cyberknight might be interested
