Thrown Chain
jimbut
What are the more common reasons for a chain throw-off ? What happened to me today was thus. Approaching lights. Slowed and stopped pedalling. At the same time geared down one level. Chain was on large ring. Did not gear down to the smaller ring. Chain popped off to the inside and wedged summat awful between BB and inner ring. This is only the second time in just over a year of riding this new ( carbon ) bike. Both times however have resulted in the same really tight wedging bewteen BB and inner ring and surface scraping to the BB area. Sure this not a good thing to happen with a carbon frame ! I believe derailleur set-up is good ( as I say, this certainly not a frequent occurence ). How do I virtually eliminate this event ? Is not continuing to pedal while down shifting the culprit here ?
lazyfatgit
Lawrence, NSW
is it possible you back pedalled?
its possible to jam the rear mech when moving to a lower gear, create a loose loop in the top of the chain, then it skips off when you pedal again?
never change gear without pedalling forward, unless your using hub gears.
Globalti
I have exactly the same problem but can't fit a Dog Fang because the carbon seat tube flares out towards the BB. I have shortened the chain by one link and this has improved matters but it still drops off about 1 in every 6 or 8 changes to the small ring.
My only solution is to fit a bolt-on derailleur with separate band then there's an expensive little device that can be bolted onto one of the mounting bolts.
Gerry Attrick
Are you absolutely certain your limit screw is adjusted correctly?
J
jimbut
Yeah, am sure the set-up is good cos as I say, only the second occurence and my stupidity caused the first when I horlicksed fitting a new chain. Interested in this dog fang. Never heard of it. Is it some sort of catcher ? Any of the usual online places stock them ?
Smokin Joe
Most places have them -
http://www.probikekit.com/display.php?code=K1108
Midlands
Check that your rear set up is as good as you think it is, check that there are no stiff links in the chain, then check that the derailler hanger is straight - if the set up is perfect the chain should always run free - never known the chain to come off at the front if the rear is right when not shifting between the front rings and certainly not when back pedalling
J
jimbut
With reference to the Dog Fang device, is it possible to obtain either that or some other catcher that would fit my BB30 frame ( Cannondale Supersix ) ??
J
jimbut
Gerry Attrick - r u the same guy who in essence said that a back pedalling action ( albeit probably a very slight one, amounting to a backward movement of the crank in this case ) would be a very likely cause of a chain throw. If forking out £10 or so protects against the sort of jam I experienced today, I am very happy to do so.
