Virtual Training
Krypton
UK
I think I've seen a system where you can plug your rollers into a PC and do virtual cycling against your previous best times, or VR opponents - is there such a thing?
Does the software control the resistance on your rollers too?
Sounds like great fun ;)
barq
Birmingham, UK
Tacx make something a bit like you describe (have a look here, I think Wiggle sell them).
I haven't used the system, but was wondering about it the other day because the weather was so rubbish. Has anyone on the forum tried one?
RedBike
Beside the road
Yes, the i-magic / fortius
Racing yourself is great for motivating you to push harder and riding a virtual route really helps relieve the boredom normally associated with using a turbo trainer.
I'm afraid the I-magic isn't very realistic. Despite the manufactures claims it struggles to replicate gradients much over 5% or low speeds. It doesn't really matter though. If you want a totally realistic ride then get a set of lights!
barq
Birmingham, UK
Ah, ok, that's interesting. Realism in the sense of graphics wouldn't bother me, but I think I might want a bit more resistance than 5%.
RedBike
Beside the road
You'd be surprised. As far as resistance goes the I-magic isn't a weakling. Most turbo trainers struggle to offer a high level of resistance at low speeds. If you want more resistance then just select a higher gear or pedal a bit quicker.
To compensate for the lack of resistance the trainer often uses a virtual speed instead of the actual speed of your rear wheel. You never actually find yourself doing 25mph up a 25% slope but you don't find yourself in first gear straining to keep the cranks turning either.
Similar threads
