Mr Pig
- North Lanarkshire
Forgive me if this has been posted before and is a well know issue, it's a head's up to SRAM chain users about the quick release link.
Yesterday, going along a rocky track on the top of the Old Kilpatrick hills I heard a clatter and looked down to see my chain lying on the ground behind me! At first I thought it had snapped but collecting the chain I realised that the link had came undone.
The SRAM power links, the quick release links, are pretty tight when they're new. In fact you need to use a pair of pliers squeeze the ends of the link together. Over time the link wears and eventually they're very loose. This isn't a problem most of the time as the chain tension keeps the link together.
What happened yesterday though was that the bouncing around on the rough track managed to shake the chain in just the right way to unclip the link and bingo, the chain's off!
In my many years of using these links this is the first time this has happened, but if it can happen to me it can happen to you. If you change your chain/link regularly it shouldn't be an issue but if it gets worn enough to be loose then you could find yourself chainless too. I'm just glad it happened on the flat and it didn't fall off as I was going down the hill, could've been a long walk back up to fetch my chain.
And carrying a spare link is a good idea too ;0)
