which bottom bracket?
johnnyh
Somerset
anyone have any idea or point me in the direction of spec for a replacement bottom bracket for a Carrera Virtuoso (08 blue and black in colour)???
if it's a case of removing the old one to find out then so be it.
cheers chaps
e-rider
crappy member
South West
Yes, removing the old one and getting one the same is the usual way to go about it.
The same size that is, you might want to get better quality though.
johnnyh
johnnyh
Somerset
yep, this one has a little play in it after about 2000 miles, but shant spend too much on a replacement since I will look to replace the drivetrain in the non too distant.
cyberknight
Can this be replaced with a hollowtech bb?
don.t see why not if your changing the whole crank set.Ask at your local LBS
Yes you can if as arch says your replacing the crank set as well although its recommended that you have the BB shell faced at the same time which is reallya job for the LBS as you could knacker your frame .
