Joffey
Big Dosser
I wish lol…. Downloaded an “emulator “ so I could install a mobile app on my pc that had wattbike on it… but none had the watt bike ! …. All the others rouvey, tacx, trainer road etc etc, one ( games loop) said watt bike was coming soon! No good ! I want it now!
Then I heard uk you can run the Atom without the hub on Zwift, but then how can you pair the gears?
Im going to try downloading the hub onto my phone and pairing the gears on there and seeing if it’ll work on Zwift .
Mot holding my breath tho!!
Thanks for yr input.
I'd forget about the PC. You need to establish if the gears are working on the wattbike first.
My wattbike changes gears (increases / decreases resistance) when not connected to any device. See if yours does the same. If it does then the gears work. If it doesn't there is a problem with your bike.
Next step is to check the bluetooth connection. As your PC isn't finding them just park that. You need to try and connect the Wattbike to your phone and use the Wattbike Hub. You should see the gear changes on your phone. If you don't then there is a problem with the bluetooth on the bike.
The above two steps should establish if there is a problem with the bike itself. If the bike and bluetooth is fine then the PC problem is your PC and you will have to fix that, or use another device.
If gears are working with the Hub they will just automatically work on Zwift on any paired device.
