mybike
Grumblin at Garmin on the Granny Gear
- Not 'emel 'empstead
As I've mentioned before I have this ancient Tesco special that I inherited from my son which I am riding & adjusting/learning to adjust.
One of the areas I've had a problem with lately is the front brake, I'd pull the lever right back & the wheel would still go round. I think I've got the answer & fixed it but knowing the expertise here thought I'd check.
Here is the RHS brake/block as it was.
So the first thing I noticed was that little L, the block was clearly on the wrong side. Then I thought that there isn't much leverage with the block near the hinge so I moved it up in the slot after swapping the pads:
Now there is a bit of an angle on the pad but it does seem to work much better. Has anyone any comments or suggestions, is there anything wrong with that I have done?
