sreten
- Brighton, UK
Hi,
AFAIUI the B screw only comes into play if you change the the rear gearing sizes to bigger.
AFAIUI on most new bikes adjusting the B screw will only makes things worse.
AFAIUI if you reduce the rear sizes, it typically won't help.
This assumes AFAIUI that the B screw is not needed for the default setup
of the derailleur and cassette on a new bike, like deraillleurs that have no
B screw, and you cannot fit larger rears, but you can fit smaller rears.
The B screw allows you to fit larger rears.
"it originally came with an 12-30 cassette, but now has an 11-28 on there. Is this why?"
Yes, in the way I understand whay it does. FWIW you could grind or fiie away the part
of the hanger that sets the position for more adjustment if thats what you really want.
rgds, sreten.
rgds, sreten.
